Sooner_Schooner
May 19, 2015Explorer
bluwtr49 wrote:Sooner Schooner wrote:
I don't use them, I just adjust the water pressure at the water spigot . I just turn the handle until it looks and feels okay.
FYI, that method doesn't adjust the pressure, only the flow rate. As soon as your water usage ceases, the pressure in the coach lines will rise to park feed line pressure.
A couple of years ago we we at a park that had a malfunction at the well head pump that caused the line pressure to spike to some very high number. The result was almost every water hose in the park bubbled and/or burst as did the lines in the clubhouse. Some coaches without a regulator suffered internal leaks from lines and/or fittings.
Well, thank you bluwtr49 and a few others, guess I learned another valuable lesson even though my little brain isn't understanding all this. Sure seems to me that if the the water is not coming out full blast then the pressure should not be too strong inside the coach. But I guess I'm wrong. Thanks.
38,782 PostsLatest Activity: Sep 10, 2026
