wolfe10
Oct 29, 2015Explorer
If you do have the second fuel filter, WITH MANUAL PRIMER PUMP, USE IT!!
If you have a Caterpillar secondary fuel filter and no primer pump, consider adding one. It just replaces the block off plate held by two bolts.
This totally eliminates the fire drill associated with changing or servicing fuel filter. You can install the filters dry and use the manual pump to prime the whole system.
