diplomatdon
Oct 31, 2015Explorer
Don't know what your definition of grime is but if you are getting grit, dirt, foreign material in the bottom of your filter in short order you have problems in you tank. If you have this "grime" in your filter you should be changing filter not just dumping it out. The cartridge material will also be full of the material. To check, replace filter then cut the old one open and have a look. Good luck.
