down_home
Oct 31, 2015Explorer II
Our Cat on Freightliner chasis water fuel separator is below tank level.
Just turn thee screw and drain out water and anything else until fuel is starting to run out.
Close and good to go.
If you lose prime at the fuel pump then installing the pump, if you don't have one is a great idea. I don't know if we have one or not.
Not going to see air up there unless you take the line off or you run it out of fuel.
