mercedesme28's avatar
mercedesme28
Waterless coolant
I have an older Bounder with a 460 engine I just had to have a water pump replaced and all new coolant put in
is it worth putting in the waterless coolant ?
I've heard about it but don't know if it's worth it or not.
Needless to say I do have to have all the new coolant drained in the system purged so they could put it in
is it worth the money and how long does the waterless coolant last compared to how often I need to have the coolant changed.
Thank you
Eric
  • Gjac's avatar
    Gjac
    Explorer III
    Will the waterless coolant do anything to remove the mineral buildup inside your old radiator? Is the specific heat transfer greater than 60-40 water and antifreeze? If not I don't think it would be worth it for an old radiator.
  • rv2go wrote:
    At about $40 a gallon, I think I would pass on it and just keep the coolant that you have. You would have to carry a jug of it to replenish if needed.
    Some makes claim lifetime.
    Amen! And since you can go 100,000-150,000 miles between coolant changes, what's the point? I've never had a coolant related failure on any of my vehicles and I do about 30k miles a year.
  • At about $40 a gallon, I think I would pass on it and just keep the coolant that you have. You would have to carry a jug of it to replenish if needed.
