Correct.......switches in photo are in 'fill' position. If connected to city water you would be filling your fresh water tank
*Both switches UP......allows city water and/or pump usage
*Left switch DOWN, right switch horizontal (pointed left)...fill fresh water tank
*Left switch horizontal (pointed to right), right switch UP is for winterizing rig plumbing system. Stick a hose in an rv anti-freeze bottle and connect it to that fitting (winterize)turn pump ON and it will pump anti-freeze thru plumbing system as you open faucets etc.
