Where is the best place to go to get MH weighed separatly all four corners-truck stops weigh fr & rear-gravel pit & junk yards do total--Is there any rv dealers in midwest (Chicagoland area) that weig...
All CAT scales (at truck stops, and CAT guarenties their weigh) I've seen are level with the ground, so if you watch driving on you can put 1 side of the coach off the scale and 1 side on, this will give you weights per axle on the one side, then reweigh the coach fully on the scale and just subtract the one side weigh to get the other sides weight.
