Do you have the "published" Front and Rear Axle weights from Jayco, or just the total "as built" weight? Even though the model number is "29" the length is over 32-feet. Wheelbase is 223 which suggests to me that Jayco is trying to take advantage of Ford's 5000-lb front axle rating and not overload the rear axle. At least take a test drive to a CAT scale and see for yourself. One, is there enough capacity left, between the empty weight and GVWR of 14,500-pounds, to carry you, your people and your "Stuff." Two, that neither axle is overloaded. Most of what you can load, will put its weight on the Rear.
