rjstractor
Jan 29, 2019Nomad
Islandman wrote:
You might have difficulty with a longer Class C (say 27 to 30+ft) as the allowable tow weight and the cargo carrying capacity are usually less than a shorter Class C (maybe a 24 ft). But if you watch what you load on the motorhome, it may be okay. We all have tendancy to put too much stuff in our MH's and that's not good when you have that Jeep Trailhawk behind you. Either way, get a good braking system no matter which way you go.
The newer Ford E450 with the V10 has a GCWR of 22,000. So fully loaded you have a 7500 lb towing capacity. The GM GCWR is 20,000, so with either rig will be within factory specs although close to max with the GM.
38,782 PostsLatest Activity: Sep 02, 2026
