j-d
Feb 04, 2016Explorer II
It helps to remember that every Class C Ford chassis has the "two valve" V10, derived from the original 1997-99 V10 that started the spitting spark plug issue. The F-Series (pickups and Class A chassis got a "three valve" V10 in the mid-2000's but it NEVER went into E-Series/Class C. The plug problems in two-valve were largely corrected in 2000 with heads called Performance Improved, with "PI" cast into them. The HP went from 275 to 305. There were some problems, albeit different, till around 2004. Around 2005 the 4R100 transmission was replaced with TorqShift, 5R110.
So... if the button on the Shift Lever says "Tow Haul" and not "OD Off" then the Class C has TorqShift AND Good Heads.
In 2008, E-Series got the new bolder grille. There were other changes, most notably an improved front axle and brakes. Rear brakes and parking brake were improved but the big jump came in front brakes. So if the Ford Class C has the "Dump Truck Nose" (for those who like it) or "Pig's Nose" (for those who don't) then it has pretty much all the improvements.
It's possible to upgrade the front axle and brakes to 2008+, but most of the other improvements Ford has made aren't within reason concerning expense and complexity.
Remember, much of a coach "year" production is on the prior year's CHASSIS. All of what I said above is by CHASSIS YEAR. I don't think it makes much difference say 2002-2003, or 2009-2010, but 1999-2000 is BIG (PI Heads) and 2007-2008 is BIG (Brakes, Axle, Styling).
38,782 PostsLatest Activity: Aug 31, 2026
