ron_dittmer
Oct 05, 2021Explorer III
pnichols wrote:For Desert Captain too.ron.dittmer wrote:
We bought our rig HERE new in 2007. It is built on a 2007 E350 chassis. The rig is garage-kept, the chassis currently driven 42,000 miles, but has lots of idling hours.
The house has been relatively trouble-free with exception to the generator of which I had to replace the fuel pump inside it, a problem that developed last year.
As for the Ford E350 chassis, it was trouble-free until our last trip out west for a month that we just returned home from. We ended up stranded on Interstate-90, the cause was a failed fuel pump control module. The Ford dealer in Gillette WY took excellent care of us with a swift affordable repair. I am now considering carrying a spare module, an easy item to replace on a roadside.
Ron, would you provide a little more detail on how to replace this (a photo or two if possible)?
I may buy a spare to carry along too, depending upon how easy it is to replace. That failing, or the fuel pump itself, is a BIG concern for me. We don't tow along another vehicle, so getting stranded along the road somewhere (or worse ...maybe out in the boonies) could be a really big deal for us.
Thanks in advance!
For our 2007 E350 with V10 engine, this is the old part and new part box. The E450 and other model years might be different.
The part is mounted to the inside of the frame about half way between the fuel tank and engine. Two mounting bolts and one electrical connector and it's replaced.
Other things to carry would be some 20 amp fuses and fuel pump relays. When the module went out, it blew the associated fuse and relay, both located in the fuse box under the hood. It is a common relay, the largest one used in 4 positions.
