devildog1971 wrote:
Now in Pahrump Nevada it has been several problems some caused by the wind like our slide awning unrolling while driving. Compounded by the wind giving us bronchitis when you are sick as we have been it makes all problems worse. We pulled into the Pahrump nugget going to look for a park later (we were so sick we did not see we were a few hundred yards from preferred R V resort frankly I did not feel like getting out of bed to move that far. The new problem is the bedroom 110 volt wall plugs do not work unless the generator is turned on or plugged into shore power there is GFI under the dining table the GFI in the bathroom other wall and microwave work on generator shore power and with the inverter on. The GFI under the table does not need to be reset just start the generator and those plugs are alright the inverter is 110 volts so I am stumped why with 110 volts from the inverter the plugs do not work
Don't have a clue as to what your coach is, but as others have said, not all rigs have whole house inverter outlets, so that needs to be decided, before any troubleshooting is done.
