dalenoel
Mar 07, 2017Explorer II
Effy wrote:
No one can tell you what PSI to run on your coach.
The only way to accurately set PSI for your coach is to load it like you are travelling (water, fuel, people, clothes, food, etc) and weigh it - 4 corners if you can, if not then at least each axle.
Once you know the weight, set the cold PSI based on the tire manufacturers chart.
Anything else is guessing.
The max on the sidewall is exactly that, the max PSI for that tire at max load. This is not what you want. It's really more of a warning.
X3 Have not done 4 corners yet but did do it per axle plus 5#
38,778 PostsLatest Activity: Jun 10, 2026
