Kidoo's avatar
Kidoo
What are the scan Codes for the 300HP cummins ISB 2003
Anyone has the codes for the 300 HP ISB 2003?
Hi, I just got my scangauge and the codes detected are 42 and 275. I have a site that list the codes for the ISB but those codes are not in. I think the codes I found are for the pre 2003 models because it list the VP44, I have the cummins common rail and no VP44 (I think!)
http://www.diesel-service-parts.com/cummins-codes.html
Any link? Thanks
  • First replace you fuel filter and if that doesn't make the code go away then get the lift pump pressure tested.
  • Well obviously the codes listed above aren't right for your CR - as you noted..
  • 111 Electronic Control Module ECM Microprocessor
    115 Engine Speed Sensor ESS Circuit
    122 Intake Manifold Pressure Sensor Circuit
    123 Intake Manifold Pressure Sensor Circuit
    131 Accelerator Position Sensor Circuit
    132 Accelerator Position Sensor Circuit
    133 Remote Throttle Position Sensor
    134 Remote Throttle Position Sensor
    135 Oil Pressure Sensor Circuit
    141 Oil Pressure Sensor/Switch Circuit Choice
    141sn Oil Pressure Sensor Circuit
    141sw Oil Pressure Switch Circuit
    143 Oil Pressure Sensor/Switch Circuit Choice
    143sn Oil Pressure Sensor Circuit
    143sw Oil Pressure Switch Circuit
    144 Coolant Temperature Sensor Circuit
    146 Coolant Temperature - Engine Protection
    151 Coolant Temperature - Engine Protection
    153 Intake Manifold Air Temperature Sensor Circuit
    154 Intake Manifold Air Temperature Sensor Circuit
    155 Intake Manifold Air Temperature Sensor - Engine Protection Circuit
    191 Air Conditioner Clutch Supply Circuit
    221 Ambient Air Pressure Sensor Circuit
    222 Ambient Air Pressure Sensor Circuit
    234 Engine Overspeed Circuit
    235 Engine Coolant Level - Engine Protection
    241 Vehicle Speed Sensor Circuit
    242 Vehicle Speed Sensor VSS Circuit
    243 Exhaust Brake Supply Circuit
    245 Engine Fan Clutch Supply Circuit
    261 Fuel Temperature Sensor Circuit
    264 VP44 Fuel Temperature Sensor Error
    278 Lift Pump Circuit
    283 Engine Speed Sensor Supply
    284 Engine Speed Sensor Supply
    285 J1939 Datalink Multiplexing
    286 J1939 Datalink Multiplexing
    297 OEM Pressure Sensor Circuit
    298 OEM Pressure Sensor Circuit
    349 Auxiliary Speed or Auxiliary Pressure Input Error
    352 Sensor Supply Circuit
    361 VP44 Fuel Valve Control High Current
    362 VP44 Fuel Valve High Current Error
    363 VP44 Fuel Pump Control Valve Feedback Error
    364 Electronic Control Module ECM to Pump Communications Error
    365 Fuel Pump Voltage Out of Range Error Low
    366 VP44 Fuel Pump Voltage Measurement Error
    367 VP44 Fuel Pump Speed/Position Sensor Signal Lost
    368 VP44 Fuel Pump Can Not Reach Commanded Timing
    369 VP44 Fuel Pump To Engine Synchronization Pulse Not Recognized
    372 Idle Select High/Low
    373 VP44 Fuel Pump Fuel Shut Off Error
    374 VP44 Fuel Pump Calibration Error
    375 Electronic Control Module ECM Fuel Calibration Corrupted
    376 VP44 Fuel Pump rpm and Fuel Error
    377 Fuel Pump Power Relay Stuck-On
    381 Intake Air Heater Relay Circuit
    382 Intake Air Heater Relay Circuit
    385 Intake Air Heater Relay Circuit
    386 Sensor Supply Circuit
    387 Accelerator Position Sensor Circuit
    391 VP44 Relay Coil Supply Circuit
    415 Oil Pressure Sensor/Switch Circuit Choice
    415sn Oil Pressure Sensor Circuit
    415sw Oil Pressure Switch Circuit
    418 Water-In-Fuel Sensor Circuit
    422 Coolant Level Sensor Circuit
    429 Water-In-Fuel WIF Sensor Circuit
    431 Idle Validation Switch IVS Circuit
    432 Accelerator Pedal Circuit ISS
    433 Intake Manifold Pressure Sensor Circuit
    434 Unswitched Battery Supply Circuit
    441 Unswitched Battery Supply Circuit
    442 Unswitched Battery Supply Circuit
    443 Accelerator Position Sensor Circuit
    444 Remote Accelerator Supply Circuit
    488 Intake Manifold Air Temperature Sensor - Engine Protection Circuit
    489 Auxiliary Speed or Auxiliary Pressure Input Error
    515 Coolant Level Sensor Circuit
    517 VP44 Fuel Pump Valve Feedback Error
    524 Switched Droop Selection Circuit
    527 Dual-Output Driver A
    528 Alternate Switched Torque Curve Switch Circuit
    529 Dual-Output Driver B
    768 Output Device Driver Transmission Shift Modulation
    779 OEM Input - Engine Protection
