wpatters1229's avatar
wpatters1229
what battery is used for starting a generator in a class C
I have a 2006 Four Winds 28ft with a standard Generator. Have not had any problems starting or running at all. Today all of a sudden it would not start...meaning it sounded like a motor that did not have enough battery to turn over. So I started the coach (Chevy Express 3500 chassis) and then tried the generator and it started just fine. If there is enough battery to start the coach engine then why would there not be enough to start a small generator? My logic says that the coach battery must have a low battery but with starting a big V8 was not a problem. Any ideas if this is something else?
  • Our generator also starts from the house batteries. There is also a relay that connects the alternator to the house batteries when the engine is running, so that the house batteries get recharged while driving. Since starting the engine allowed you to start the generator, you must have a similar system.
  • Our generator starts from the coach batteries. If they are drained you can start the engine, then the alternator will provide power to the coach battery, which will in turn allow you to start the generator.
  • I had a 2006 Triple E and it had a two way charging system on it. When the coach was plugged in, the system charged the chassis, and when the chassis was running, it charged the coach.
    Yours might be like that, and when you ran the motor the voltage to the coach was high enough, so your generator started.
    Check your coach batteries with and without the engine running to see what the voltage is. I believe the generator should start from the coach batteries.
  • Sounds like the generator is wired to the coach battery, not the chassis battery.
    You can always use the battery boost button to start if need be.
