Bobalooie
Aug 09, 2019Explorer
rk911 wrote:
the specs on the first link indicate a 5K difference between the GCWR and GVWR on the Freightliner chassis which to me indicates the hitch is a Class III capable of towing 5000-lbs.
but keep in mind that the amount of weight you can safely tow will be the lesser of the following:
- the gross combination weight rating of the MH minus the *actual weight* of the MH as it is loaded and configured for travel
- the weight rating of your hitch
- the weight rating of your tow bar
before you buy a toad you need to know what your mh weighs as it is loaded for a trip. that includes full fuel, fresh water and lp tanks, food, clothing, supplies, pets and people. get separate axle weights to make sure that neither axle is is overloaded. then apply the three tests above. for every pound your mh exceeds its gvwr you lose a pound of available tow weight.
Thanks. Yes, I suspect it is around 5000lbs. We are pulling a horse trailer with a couple horses, so would need the 10,000lb hitch.
