rgatijnet1
Jul 10, 2017Explorer III
A simple pressure test can find if there is a leak. After that, the location can be pin pointed.
Some people use the wrong product to clean their radiator and this can lead to corrosion. Salt from Winter roads can also cause corrosion.
Simple Green EXTREME is recommended to clean aluminum and if it is not rinsed COMPLETELY, it will not cause more corrosion. Some of the other cleaning solutions actually make things worse if they are not rinsed out of every little gap.
