AllegroD
Jul 25, 2014Nomad
If you do a search you will find a lot of discussion on 30 vs 50.
You can run 1 major appliance (i.e. AC, MW, Space heater, elec WH) and if you have an EMS you might get away with 2. Running the fridge at the same time as one of the major appliances should not be a problem. The reason I say SHOULD NOT is because I do not know how many start up amps your AC and fridge require. Look the starting mps up for your appliances. Anything over 30 won't work. If you have 2 major appliances running and the fridge kicks on, you will probably throw the CB.
38,769 PostsLatest Activity: Mar 31, 2026
