Peralko
Jul 26, 2014Explorer
bshpilot wrote:
As Dennis says ! Dryer outlets are 240 vac !
Dryer outlets, Electric Kitchen Range & Welding outlets are a NO NO (all are 240v)
That's right! Just like a 50-Amp outlet for an RV. Each leg has 120 volts and 240 volts between them. If you set up a 50-Amp outlet for your house, you would use the same circuit breaker as you use for 240-volt appliances. But if you don't know what you are doing, please have a professional do the installation!
38,769 PostsLatest Activity: Dec 31, 2017
