prlandry
May 01, 2014Explorer
smkettner wrote:
IOTA really only goes 14.6 then you have 15 minutes before it drops to 14.2 volts. The 14.8 is only the max if you hit it during that 15 minutes. Still an excellent converter.
With #6 wire (how long?) I would stick with 55 amps. I am not big on parallel conductors and neither is RVIA and NEC. Low battery will still take a solid three hours to get to 90%. Larger wire is better. Since you are pulling wire I recommend going #4 even #2 if it will fit the connectors. Also the 15 amp outlet limits you to the 55a version.
I haven't measured the exact length but I'm guessing around 12 feet... I can double up the cables as these are pretty good quality and are free.
I was originally looking at the pd9260 but then read about the iota pushing just a bit more volts that would be better(I think) to charge up my new t105's as per the charging recommendations.
If I went with a bigger converter say the iota 75... would this be more efficient at quickly charging my batteries while not being to harsh on them?
38,766 PostsLatest Activity: Jan 10, 2026
