OhhWell
May 02, 2014Explorer
prlandry wrote:smkettner wrote:
IOTA really only goes 14.6 then you have 15 minutes before it drops to 14.2 volts. The 14.8 is only the max if you hit it during that 15 minutes. Still an excellent converter.
With #6 wire (how long?) I would stick with 55 amps. I am not big on parallel conductors and neither is RVIA and NEC. Low battery will still take a solid three hours to get to 90%. Larger wire is better. Since you are pulling wire I recommend going #4 even #2 if it will fit the connectors. Also the 15 amp outlet limits you to the 55a version.
I haven't measured the exact length but I'm guessing around 12 feet... I can double up the cables as these are pretty good quality and are free.
I was originally looking at the pd9260 but then read about the iota pushing just a bit more volts that would be better(I think) to charge up my new t105's as per the charging recommendations.
If I went with a bigger converter say the iota 75... would this be more efficient at quickly charging my batteries while not being to harsh on them?
The harsh part would be in the microprocessor that handles the charging. The converters you are looking at with at least 3 stages should be fine. 75 amps DC should be ok on a 15 amp 110v circuit as it will likely pull about 10 amps max on the 110 side. Running parallel wires obviously isn't as good as a single heavy gauge but... it does work. I wasn't aware of any complications besides 110 draw, wire thickness and battery specs in limiting the DC amperage capacity to charge faster.
38,766 PostsLatest Activity: Jan 10, 2026
