wildmanbaker
May 02, 2014Explorer
If you are going to use the on board generator, then get the biggest converter you can, to recharge the batteries. If you will use a 2,000 Watt invertor generator, it may overload it at times, dropping the generator off line. We had a 75 amp converter, and as it started going bad last year, I replaced it with a 55 Amp converter to keep from overloading the small inverter generator.
38,766 PostsLatest Activity: Jan 10, 2026
