tropical36
May 02, 2014Explorer
prlandry wrote:
Hi guys,
I'm the new owner of an older class A MH... a 1996 triple E commander DP and the house batteries are shot and I knew before buying it that they would need to be replaced.
I just ordered 4 t105's and I'm in the middle of picking out the right charger for me.
What I'm looking for in a new charger is that it can charge the batteries in the least amount of time off the 5kw onan onboard gen. And it would be way more convenient if I could run the charger off of a 15amp shore power (unless it will require a charger that won't be as effective to quickly charge the t105's)
I have pretty much made up my mind so far to go with the iota chargers due to them being able to push 14.8v as required by trojan.... I just need to decide what size I should go with. 45,55,75amps???
I plan on mostly boondocking with my rv and when my parents use the rig they will probably be hooked up to shore power more often then not.
I can't seem to find a quick answer and most of the long explanations I have found are over my head. Someone on here should be able to give me a quick answer.
I want to order my new charger in the next few days as my new batteries will show up monday.
This is a great site with plenty of good info... looking forward to what you guys suggest I go with amp wise.
Thx
Peter
I replaced my original with this one, couldn't be happier with it's performance and it should suffice for you also...CONVERTER CHARGER
38,766 PostsLatest Activity: Jan 10, 2026
