- koda55ExplorerHad a fresh water leak so I pulled both tanks out. Found the previous owner had put plummers putty around two pipe connections. One fitting in each tank was stripped out. Now waiting for dealers to see if he find fined me two tanks.
- Dutch_12078Explorer III
toomoxy wrote:
sailor_lou wrote:
toomoxy wrote:
sailor_lou wrote:
Just when I was about to install new wiper blades I noticed the arms were pretty faded with some light rusting and overall, looked pretty crappy. Also, one of the arm spray nozzles was broken and was just hanging by the rubber hose. I removed both arms, sanded and primed them and will repaint tomorrow. I also ordered two new spray nozzles, which hopefully will be delivered before we head out next Friday.
Lou
05 Travel Supreme Envoy
My squirt hose on my wiper had to be replaced as snapped off.
Now I notice my spray is only hitting the top of the windshield..
is this normal do you know ??
When working properly, mine spray from the center of the wiper blade both up and down on the windshield and no where near the top of the windshield. I have Dyna wiper arms and the nozzles are attached with the same screw/nut the holds the blade to the arm. Maybe it has shifted and is now aimed too high. If that is not the case and they are damaged, you can buy just the spray nozzles or a complete kit with nozzles, hose and clamps. I purchased them from here:
http://www.millsupply.com/
I ordered the parts on Friday (6/7) at 10:49 AM and according to the tracking info I received, I'll have them on Mon (6/10), so I'm impressed so far. Good luck.
Lou
Thank you for the information...crap something else to repair... but better now then later...
Check your nozzles for a screw slot in each one. Mine are individually adjustable just by rotating them with a small screwdriver. - toomoxyExplorer
sailor_lou wrote:
toomoxy wrote:
Lou
Lou
Thank you for the information...crap something else to repair... but better now then later... - toomoxyExplorer
Canadian Rainbirds wrote:
Put some stain on what I hope to be new shelf behind the flat screen at the front. I have the surround in the basement but the rig is still in the shop for water leak issues from the shower.
Also, not directly rig related, but yesterday evening and today I finally posted to our blog the entries recounting our last few days returning home from Mexico. Just a little tardy, the entries are dated from late March!
Look what the tech found while checking for wear and tear. :E
$800.00 for that repair sounds pretty good... I wonder how much
it would have cost in Canada ... - sailor_louExplorer
toomoxy wrote:
Lou
Lou
05 Travel Supreme Envoy - FCExplorerI changed the oil and the filter for the genny, constructed a pull out shelf for my tool box from one of the basement storage bays and polished the head light lenses to a beautiful clear finish.
- punomaticExplorerChanged out the transmission temp sender on my 25 year old coach. I have been looking for one for five years. I finally found it at Custom Instrument Panels. Great company to do business with. They sent one out, and it was the wrong one. They sent the replacement from NC to OR in 3 days with a note attached asking me to please return the first one when it was convenient. (I had already sent it.)
I also put a coat of Rustoleum primer and two coats of silver metallic paint on the shelves in the fridge. The plating was pealing off, and new shelves are $50 apiece! Spent $15 instead of $200. DW says it looks like a new fridge. BTW, does anyone know how to spray wire shelving, without wasting 90% of the paint on overspray? - ctpresExplorerTried to figure out why both A'cond won't run on gen. Less hair do to scratching head.
- Canadian_RainbiExplorerPut some stain on what I hope to be new shelf behind the flat screen at the front. I have the surround in the basement but the rig is still in the shop for water leak issues from the shower.
Look what the tech found while checking for wear and tear. :E - RhondaExplorerSanitized fresh water system and put new wipers on. Loaded everything up for a 4,000 mile trip.
38,769 PostsLatest Activity: Jul 09, 2020
