- TrapExplorerWashed and polished one wheel, will try and do one more today. Polishing Aluminum rims is not something I want to get done in one day. At this rate it will take me most of next week to get done;)
- gonefishin77ExplorerChanged out analog t-stat to digital, replaced fridge/freezer black plexiglas fronts with wood grain panels. Built wood counter extension for kitchen. Put wall accessories up using Jacknuts (cool system). Removed rear tv to use cabinet for storage. Changed out old front tv for new LCD on a swing arm for better viewing on couch.
Been a busy winter!! - TubaronnieExplorerUnzipped cover, started her up, ran gennie for a couple of hours under load-all in zero degree weather. Ran like a charm-not bad for 19 year-old coach!
- revumpExplorerEnjoyed just sitting ... nothing to fix at the moment
- Dutch_12078Explorer IIIToday I upgraded our TPMS from a TST 510 series to the newer 507 series with replaceable batteries. The sensor setup is much quicker on the 507, and the hardwired power connection and long range antenna from the 510 plugged right in to the new monitor with no modifications. I had intended to replace the ten 6 year old sensors on the 510 system, but TST called me with a deal on the 507 that I couldn't pass up when I emailed them about refurbing sensors.
- SkiingSixPackExplorer
toomoxy wrote:
What wonderful memories you are making !! I just want to know how you stayed warm ?? space heater or using the propane heater ?? What worked ?
We use a Mr. Heater Big Buddy plumbed into our propane line (since it is low pressure). This helps keep the 31.5 foot single pane window motor home quite warm, even on low. If it is really cold, say less than 0 and windy, we have to bump it up to med or hi.
We do not sleep in this as we only live 40 minutes away, we just use our RV ski chalet for day trips... Although there are many here that do sleep with the Mr. Heater on and there are plenty of ice fishermen that swear by these heaters... They are well-built products and the "Big Buddy" has the low pressure quick connect inlet.
Usually we are outside, though, dressed for the cold. Kind of like ski tailgating :-) - koda55ExplorerHad the slide repaired. Then changed oil and filter in the steering and cooling system. Changed filter in air dryer.
- toomoxyExplorer
SkiingSixPack wrote:
We took our old 1984 MH out on a much needed RV Ski day and evening to our little old local ski area, Welch Village in Welch, MN. Great weather and and a great family day with all 6 of us and our 10-month old pup. Summit did great and proved his ability to stay close and make friends :-)
I feel blessed that the kids can still have fun with us! :-) I love to ski and these RV ski days are the best!!! Love to see these smiles!!!
What wonderful memories you are making !! I just want to know how you stayed warm ?? space heater or using the propane heater ?? What worked ? - Dale_TravelingExplorer IIReplaced a slow leaking power steering pump and added Firestone air bags on all four corners. Ride is a bit better but not night and day.
- Hank_MIExplorerReinstalled another dual pane window I resealed.
38,769 PostsLatest Activity: Apr 10, 2026
