- revumpExplorerReplaced the rearview camera, serviced the washer/dryer, fixed electrical system, shower water control, removed decals, buff and polish ... little time and $$$$
- mikeintnExplorerYesterday new Autolite plugs, Ford Racing 9mm Spark Plug Wires, MSD cap and rotor. Today ripped out carpet down hall and around bed in bedroom to prepare for new laminate flooring.
- GORVN4FUNExplorerShoveled the 4 feet of snow that was plowed up in front of it at the storage yard with the hopes that it will melt before the end of the month. What a winter!
- UseroverdriveExplorerFrom yesterday and today: Bosch platinum +4 plugs, Accel 9019c high temp ceramic plug wires, MSD distributor cap/rotor assembly, coil, PCV valve, crankcase breather. I also installed a K&N air filter a week or so back. The difference is amazing, just at idle.
Next, the roof and finally tires - BigRabbitManExplorerContinued working on the transformation of the power system of my coach. Here is a link to page 15 of the photo album that follows the project. Today I worked on the dash by removing the original gauge cluster in preparation for installing the new cluster.
Old cluster out, new one getting ready.
If you like, you can page back to the start of the album and follow the project from its beginning to the current status. - Not_a_Yurt_ExplorerWe discovered (after purchasing) that the windshield washer pump in our used Winnebago was an inoperable block of corrosion. Today I stopped by the auto/scrap recycler and pulled a washer tank and pump out of a junked truck. Brought it home, hooked it up, and it works like a charm. For free-and you can't argue with that! The truck was headed for the crusher, so the guys in the yard said, "Go at it." Small town living has its benefits! Thanks, guys!
- UseroverdriveExplorerReplaced old air filter with K&N lifetime performance air filter
- BigRabbitManExplorerReplaced my Flojet fresh water pump with a Shurflo.
I had persistant leak issues with the snap in fitting on the Flojet leaking. So after a number of years and fussing with it, I replace it with the Shurflow which doesn't use O-rings and can be tightened to ensure no leaks.
My leak issue is now gone! - st687ExplorerOrdered 8 air bags,8 shocks,8 return springs for the calipers.
- zmotorsportsExplorerI replaced the chassis batteries with new NAPA HD 31 Commercial batteries, I also noticed that they have a few more CCA than the previous ones (950CCA vs. 900CCA). I also noticed that the battery end on the positive cable had some corrosion starting and it had gotten into the cable strands. The cable was barely long enough to reach as is so there wasn't enough to cut off and install a new battery end. I had to build a new cable so I picked up some new 4/0 cable and some ends while at NAPA as well.
Here is the new cable cut, crimped and heat shrink applied next to the OEM cable.
New cable with the convoluted casing and ready for installation.
One item that has bugged me since purchasing the coach back in 2007 was the fuse holders that were merely folded back upon themselves and zip-tied to the battery cables. There are seven of them and they were ziptied to the positive battery cable down between the chassis batteries and the engine belt/accessory train near the battery shut-off switch. This looked cluttered and horrid and I am frustrated with myself that I didn't do something about this seven years ago when we first purchased the coach. It is the one thing that kept bugging me every time I would open the engine access to check fluids and/or perform any maintenance.
I decided to use a piece of 2"x 1/4" aluminum angle that I had in my scrap pile. I know it is overkill and could have used some much lighter gauge aluminum but I didn't feel like digging out the break to bend up a thinner piece. This was handy so it is what I used.
I laid out the fuse holders to figure out a configuration in which to attach them that would look nice yet allow me to keep the same wiring without having to completely rewire the whole thing.
Here I am drilling the holes to attach the fuse holder. There are also two 1/4" holes on the top side that will be used to attach the aluminum panel to the crossmember which goes across the engine bay just above the chassis batteries.
Painted and ready for installation.
Here is a picture with the panel installed and all seven of the fuseholders installed. I also added some convoluted casing over the wiring.
When we first purchased the coach I had a lot of interior (house) lights that did not function. Upon quick voltage checks I realized that I was missing about half of my circuits. I traced back through the electrical distribution panel and found two 12 volt continuous duty solenoids that when energized transfer the 12-volt power from the house batteries to the electrical distribution panel. One of those relays/solenoids were bad. I replaced it and all was good. However, fast forward to 2014, the coach is 11 years old with 95k miles on it and upon testing I found the other relay/solenoid was bad. Upon testing with a meter I found that I had high resistance when the solenoid was activated so the contacts inside were pitted/damaged. I just decided to replace them both so I wouldn't have to worry about it throughout the RV travel season.
I also carry a spare solenoid just in case but I replace the two in the rear electrical panel located in the engine bay. Here are the solenoids/relays with the electrical pane cover removed. The very bottom one is the original that I did not change when we purchased the coach.
NAPA/Echlin part numbers (ST85). These are continuous duty solenoids that have an isolated ground on the coil (not grounded through the mounting). The ground is actually the side that is switched from a small switch just inside the door of the coach to kill all of the house 12-volt electrical.
New solenoids/relays installed and ready to reinstall the cover.
Rear engine bay all completed and ready for another travel season.
For the most part she is ready to go. Once the weather gets a little warmer I have a couple of spots on the streetside that I need to paint as I have some clear starting to peel off. The curbside still looks like she rolled out of the factory so by touching up the left side maybe I can buy myself a couple more years before having to paint the entire coach. $$$$$$
Mike.
38,769 PostsLatest Activity: Jun 25, 2013
