- SRTExplorerDW started to clean out the motor home after 14 years of traveling. It will be going up for sale after it is cleaned out. My lung problems have slowly gotten worse where I can't do much but just sit around as my breathing can't oxygenate my blood fast enough if I move too fast.
Lots of fond memories and it will be sad to see it go. But I'll still hang around RV.NET. - ctpresExplorerCleaned the MT. bugs off front cap.
- sailor_louExplorerJust finished up adjusting the valves on my CAT C7. Only a couple of them really need adjustment, but I spent about 4 hours because I'm borderline insane and always try to get them all in the middle of the spec.
Lou
05 Travel Supreme Envoy - D_E_BishopExplorerWell so far today I have removed the DW's surfboard(joke there)and started rubbing out the overspray from painting the trim where I made to the rear cap. I am on my way to a glass shop where I will pick up the cabinet doors I routed out to accept smoked glass that will let the IR beam from the remote for the BluRay player in to control the player. After that I think I get some rubbing compound and rub out the rest of the rear cap and where the RMP is flaking from sunburn. By then the DW should be home from her quilt guild's Helping Hands, sew in and I'll make dinner for her. That philanthropic work will wear a girl out so she deserves it.
- vickileaExplorerHusband built a paddleboard rack on the back of the motorhome and we got a tandem bike which we had to makeshift to get on the bike rack with the paddleboards.
- gfs1943ExplorerToday I did nothing, but yesterday I changed the oil and all filters (oil, fuel, air) on my generator. The day before, I had a satellite guy come in to help get my Dish Network service working in the coach. And, over the past week or so, I've greased the fan bearing and lubed the exhaust brake, fixed an interior light, and installed a PD9260 converter to replace the Heart Interface inverter that fried itself last year.
Now, I gotta change the engine oil & filter, both fuel filters, and grease the rest of the chassis lube points underneath. - UseroverdriveExplorerNew water heater for the S&B installed. Just installed the bodyspa shower upgrade in the mh and will test it later tonight
- UseroverdriveExplorerGenerator repaired. Now testing the atwood hot water system, since the main house hot water heater died...
- et2ExplorerPut the new foam topper on the mattress. Sprayed the slide out seals with silicone. Pulled the lanyards for the air tanks. Had the oil changed last week ( first change ).
- Jim_NormanExplorerChanged the oil. 6.5 quarts of Mobil 1. Ordered the Helwig adjustable links to do the sway bar upgrade. Have to freshen the water tank this week.
38,769 PostsLatest Activity: Jun 25, 2013
