- NevadastarsExplorer
woodworker414 wrote:
I decided to wash the Chateau. Get rid of the road grime. It needed it. I start on the rear. When finished I went to the streetside. Staying ahead of the sun. As I came around the corner, I heard a noise. So I walked up the side of the C, and found out that the furnace was running. UUUUUMMMMMMMM, its not on. I go inside and check the thermostat. Switch is set to off, and fan switch is set to auto. I move the switches and the blower still runs. To shut down the blower, had to pull the fuse. Back to the dealer this coming Thursday.
What do you think would cause a blower on a furnace to come on by itself?
Have a great weekend.
Remember why its called Memorial Day.
My guess would be a bad switch. Not sure what else it could be. - woodworker414ExplorerI decided to wash the Chateau. Get rid of the road grime. It needed it. I start on the rear. When finished I went to the streetside. Staying ahead of the sun. As I came around the corner, I heard a noise. So I walked up the side of the C, and found out that the furnace was running. UUUUUMMMMMMMM, its not on. I go inside and check the thermostat. Switch is set to off, and fan switch is set to auto. I move the switches and the blower still runs. To shut down the blower, had to pull the fuse. Back to the dealer this coming Thursday.
Remember why its called Memorial Day. - NevadastarsExplorerWent to Lowes and picked up a nice satin finish Delta faucet to replace the original white one that started to leak.
waianaegal wrote:
taking it and the toad from Minden NV to Placerville CA, yippy over Echo Summit in the Sierras... mid week should be ok...
Have fun, but you know you will have a bunch of impatient motorists in cars behind you,especially coming back up the hill. Been that route many times, but not in the MH. - suicidetunaExplorerThis week I finished the TV mount for my 50' and upgraded to HID lights.
Next week I have to finish up the Invisibrake install and then the Directv satelite.
You can see all the upgrades here:
https://www.youtube.com/channel/UCIE4uLJbg5F-ET52BKpd3dg - waianaegalExplorertaking it and the toad from Minden NV to Placerville CA, yippy over Echo Summit in the Sierras... mid week should be ok...
- klutchdustExplorer IIA small panel below the sink has a light switch mounted to it, very thin paneling. It broke free from the framework so I glued two pieces of 1 by 2 behind it to add some support. It was stapled on but chinsy by all means. Also cranked up the satellite dish to get TV reception so I don't have to re-set the receiver on the computer from non use. El Mirage time trials out in the desert coming up, can't wait. The other day I took advantage of the rain and soaped it up and let the rain do the rest....
- RE_ToddExplorerDrove it
- tenbearExplorerToday I de-winterized the MH. Drained the antifreeze, filled the fresh water tank and lines with chlorinated water, let it sit for 4 hrs then drained it. refilled with just water, drained and refilled. Ready to go now.
- VagabondRetireeExplorer
tenbear wrote:
How old were the tires?
They were 2011 but I was going by mileage on them, not smart, now I know.
38,780 PostsLatest Activity: Jul 05, 2026
