Dale_Traveling
Jan 08, 2016Explorer II
Next time you fill up watch the what happens. There's a gas bleed valve at the 80% level that will spit liquid propane when the liquid reaches the 80% point. Then check your gauge both on the tank and in the coach. You know the tank is physically filled to 80% so compare that to the various gauges.
I'm pretty sure with my rig the mechanical gauge on the tank will indicate 80% but the electronic indicator inside will read 100%.
38,778 PostsLatest Activity: Jun 07, 2026
