supercub wrote:
I have a piece of trim coming loose on the side of my motorhome. It appears to be held on by adhesive. It's an 04 Fleetwood Revolution. Any idea what kind of adhesive to use to glue it back. It's a trim strip that is about 2 inches high, about 1/2 inch thick and runs most of the length of the motor home. It appears to be the same material as the side of the motorhome. An area about 3 inches is lifting. Thanks
Brian
Whatever you use just be sure to get the surface and parts clean - really clean - then any quality adhesive should work.
Best of Luck,
