- BobRExplorerOld Ford 460 running 87 octane per owner's manual.
- K_CharlesExplorerThe compression ratio is only about 9:1 so you can use regular gas. They have found better ways to make power then raising the compression ratio.
- gboppExplorerOur 96 Southwind, 454, works great on 87 octane.
- dayaksterExplorerThe previous owner of my 97 Allegro Bus said he ran regular too. Thanks for the question as I was in need of opinions also.
- Coyote74ExplorerMy 8.1 GM workhorse uses regular gas. I had a 454 chev used reg and 2 workhorse over the years all ran fine on reg gas. East coast, south and north plus Midwest areas.
- EffyExplorer II87
- RetiredBobExplorerNo, 8.1L calls for 87 octane.
- fourmatExplorerthe premium requirement in old big blocks was due to compression ratio and carb the V10 has EFI fuel management and runs on regular
38,769 PostsLatest Activity: Mar 31, 2026
