Ivylog
Feb 05, 2017Explorer III
I'm aware that you weigh and then set the pressures BUT for my rig the listed pressures are within 5 psi of what I need to run on the front and drive axle and 10 psi on the tag. On the 40' rigs without a tag I'll bet you'll be within 5 psi of the listed pressure (some 130) loaded up for half/full time RVing. You do not put a 265 on the tag unless you need it to carry 17K or more.
I wish they were required to post a CCC amount like they used to as then you had a better idea of how much stuff you could put in it.
A bath and half is a full bath in the rear plus a half mid coach.
Blaster man, what pressures are you using? I agree a tag coach will likely be able to back off the pressures by 8-10 psi.
