holstein13's avatar
holstein13
Explorer II
Aug 09, 2015
What is a Jake Brake?
In class this week, the instructor attempted to describe for us the Jake Brake.
Here's what I understood. He said that the Jake Brake on my engine (ISX 15) is called the Interbrake. It is built into the engine by Cummins and works by introducing fuel during the exhaust cycle of the cylinder movement and withholding fuel from the compression phase. In other words, instead of helping to propel the drive shaft forward during the compression phase, the engine applies pressure to the cylinder when it's in the exhaust phase effectively applying the same amount of force it would to propel the engine to effectively slow the engine. It's almost the same as reversing the current on an electric motor while it's in motion.
He said that in the past, Jacobs made Jake Brakes that were bolted on to the engine and did the same thing, but these systems weren't muffled and in some cases, you could see flames shooting out of the exhaust. I'm assuming this was either a separate exhaust or fuel was introduced in the exhaust system somewhere down further.
Other engine brakes restrict the exhaust to slow the engine but these systems are not as powerful as shooting fuel into the exhaust phase of the cylinder. Jacobs claims that their systems can produce as much braking power as the engine has horsepower. One of the confusing parts of this explanation is that every brake designed by Jacobs is considered to be a Jake Brake even though it may work differently.
Is my understanding correct? Can anyone add to or help me correct this?
