j-d
Aug 21, 2015Explorer II
Every LT225/75R16E tire has the same load ratings. That said, the best tires in this size will ride/handle/last a little longer than the good ones.
If your coach is heavy, if you use it a lot, if you drive in hot summer temperatures, I'd suggest the best ones.
IMO, two stand out as Best:
Michelin XPS Rib and Bridgestone Duravis R250 both of which are highway tread.
Again IMO, Good ones are:
Michelin LTX which is the OEM tire on E450 and it's M&S tread along with a few others like Firestone Transforce and BFGoodrich Commercial T/A. Lower volume tires I hear good things about are Hankook and Kuhmo,
RV's are heavy, driven long highway miles. I can't recommend the $100 or so cheapies that are also available. Too much at stake. The danger aside, a blowout can cause thousands in damage to an RV.
