SidecarFlip
Nov 27, 2017Explorer III
theoldwizard1 wrote:
For that vintage Ford, the engine control computer does not know anything about what is going on inside the transmission.
You may already have an auxiliary cooler installed. It would look like a small radiator and sit in from of the radiator and AC condenser.
Adding a transmission temperature gauge is a good idea.
+2.
Your check engine light is something engine, not trans related and a 1990 vintage would be a C6 and that would definitely benefit from at the minimum of a 6 pass cooler
Sounds to me like low oil pressure, low oil level, clogged pickup strainer or a failing sender unit. Idiot lights work on the principle of continuity. I'd install an oil pressure gauge and a trans temp gauge if I owned the unit.
You might try a heavier weight oil first.
38,774 PostsLatest Activity: Apr 26, 2026
