gutfelt
Nov 27, 2017Explorer
McGruff38 wrote:
I have a 1990 Fleetwood Flair 26 footer with a Ford 460 and 3 speed auto trans. The motorhome is rated at 3500lbs towing capacity, and I am right about there with my trailer and sandrail. My concern is my check engine light comes on periodically, and when Im climbing hills it stays on. Once im not climbing, it will turn off after 30 sec - 2min or so. Sometimes my engine temperature doesnt even have a chance to start climbing before it goes on, so Im assuming my transmission is getting hot. I dont have a temperature gauge for the trans, so im relying on the check engine light. So my question is, can I add a transmission cooler/gauge to this motorhome? if so, how much should I be expecting to pay for something like that?
sounds like a weak o2 sensor or even may be a emissions control mile service due lite;;regarding cooler easy to add on just make sure you put it between the rad out line and trans in line
38,774 PostsLatest Activity: Apr 26, 2026
