RLS7201
Nov 28, 2017Explorer II
gutfelt wrote:RLS7201 wrote:
No computer and no codes on the OPs chassis. He has an Oshkosh chassis with 460, carburetor & C6 transmission.
Richard
he has a system of some sort because he has either a service engine or check engine
so definitely has a ecm type deal of some sort sending signals from sensors etc
if its a 1990 and its not efi as u say its not then its about a 1986 or earlier engine system
I believe its powered by a 460 EFI system if its a 1990 MH
but anythings possible so if it is carbed its a 86/87 engine series
Well you are wrong. He does NOT have a Ford built chassis. He has an Oshkosh MH chassis with a Ford 460 engine and transmission. Oshkosh used a carbed 460 and C6 transmission up to 1990. Then for one year, in 1991, they built a MH chassis with 460 EFI and C6 transmission.
All Ford built F53 MH chassis with 460 are EFI and E4OD transmissions. 1988-1997.
The clue to what the OP has was in his first post. He said 3 speed transmission with 460.
NOW YOU KNOW............
Richard
38,777 PostsLatest Activity: May 20, 2026
