77rollalong
Mar 18, 2018Explorer
most newer systems have both a high pressure switch, and a low pressure switch. i have seen in some cases where if the low pressure switch trips too many times due to low Freon the body control module will lock out the AC system until the system is charged properly and either have had to manually run a jumper wire to the clutch to the battery so i could put in the correct amount, then clear the code and would run proper after that..
38,773 PostsLatest Activity: Apr 24, 2026
