pnichols
Feb 06, 2015Explorer II
Stranger wrote:
pnichols wrote:
DaHose wrote:
I had to use mine once too, when my voltage regulator died. Pain in the butt to drive holding the button.
I have since installed a new battery combiner circuit that automatically bridges the batteries on startup. However, I also need to wire in the AUX button, so I can still hold it in to manually bridge the batteries if anything happens to my voltage regulator again.
Jose
Hmmm ... why couldn't one use a special cable they easily put together ahead of time that has a male 12V plug on each end. Plug one end into a coach 12V outlet and the other end into a 12V outlet on the dash in the cab.
This setup could backfeed 10-12 amps from you coach batteries into your chassis electrical system to maybe run the motor's ignition system (no lights on, though) so you could keep moving. The same thing could be done by running the coach's built-in generator to power a charger plugged into a coach 120V AC outlet with it's output plugged into a dash 12V receptacle as you drive.
This is just brain-storming on my part - never (yet) had to try it!
Stranger responded:
"Don't need to be "Snarky" but, I'd love to see the SPARKS using this method."
Hhhhuuuuuuh??
How is going from the coach batteries (via a cigarette lighter plug in the coach) to the chassis battery (via an always-hot cigarette lighter plug on the cab dash) going to smoke anything?
Also: "The same thing could be done by running the coach's built-in generator to power a charger plugged into a coach 120V AC outlet with it's output plugged into a dash 12V receptacle as you drive."
I do about the above all the time when the RV is in storage at home ... except the coach is on shore power instead of generator power. I plug a small charger/maintainer into a coach 120V AC receptacle and then plug the charger/maintainer's cigarette lighter plug adapter output cable into a always-on 12V receptacle on the cab's dash. This keeps my 6-7 year old chassis battery always fully charged so it doesn't sulphate and is therefore as good as new after all these years. ;)
38,766 PostsLatest Activity: Jan 10, 2026
