dperkinstx's avatar
dperkinstx
What is the Aux Start switch for?
I have this switch on the dash of my '94 Minnie Winnie. What is it supposed to do?
  • I had to use mine once too, when my voltage regulator died. Pain in the butt to drive holding the button.
    I have since installed a new battery combiner circuit that automatically bridges the batteries on startup. However, I also need to wire in the AUX button, so I can still hold it in to manually bridge the batteries if anything happens to my voltage regulator again.
    Jose
  • If the chassis battery is dead, press AND HOLD the AUX (emergency start) button while turning the key to start the engine. This lets the engine try to start using the house (coach) battery(ies). Once the engine has started release the AUX button.
  • Starts the Aux in case the donkey dies ... :)
    Sorry - yeah, ties the house and chassis batteries together for starting the engine in case you run down the chassis battery
  • If for some reason your starting battery goes dead or weak, that button will temporarily tie in your house battery to start the engine.
