danager
Apr 30, 2014Explorer
If it started leaking on its own, I would recommend replacing it. Because you opened the valve and now it continues to leak a bit, this may not be as serious.
You could try this absolutely FREE procedure.
Take a pair of needle nose players and push in on the stem that was pulled out when you flipped the lever up.
38,780 PostsLatest Activity: Aug 05, 2026
