TucsonJim
Apr 30, 2014Explorer II
Please note. Just some simple safety preparation if you do decide to remove and replace it. Make sure the water heater is off, then open the relief valve before you try to unscrew it. If the hot water heater is pressurized and you try to remove the valve, you can injure yourself with high pressure scalding hot water.
38,782 PostsLatest Activity: Sep 10, 2026
