hipower
May 01, 2014Explorer
A little silicone lube on the shaft usually helps the valve to seal better since the spring is marginal due to it's design requirements. Also a slight tap on the shaft will often reseat the seal.
As most have stated though the surest solution is a replacement.
38,782 PostsLatest Activity: Sep 10, 2026
