J-Rooster
Aug 04, 2013Explorer
wny_pat wrote:I'm always afraid of getting contaminated fuel! Sometimes it's the tanker drivers fault especially if it's water in the tank. Back in the day when I hauled refine fuels I would always put my trailer up on blocks at the end of the shift and let the tanks drain to get anything out that was in there! I agree with you on trying to drain the tank and changing the filter. I had to drain my fuel tank in the RV 2010. Good Luckn4hwl wrote:I've pumped out lots of big underground fuel tanks at truck stops and gas stations. Sounds just like the******that was on the bottom of the tanks. Called refinery sludge. Have you fueled up recently where a transport was unloading fuel? That stirs up all that sediment and it gets pumped out to who ever happens to be fueling up. You can't depend on the stations filters to filter it out because they don't get changed enough and go on bypass.
found this same reddish/brown gunk in the bottom of my fuel filter to the cat c7. It was down in the clear plastic cap on the bottom of the filter.
38,766 PostsLatest Activity: Jan 10, 2026
