barmcdExplorerNov 19, 2015What is this?This picture is in an ad for a 1999 Monaco Diplomat on RV Trader. I've never seen anything like this before.
7 RepliesReplies sorted by Newestwolfe10ExplorerNov 19, 2015And spark plug replacement or valve adjustment would likely require removing it from the coach.PogoilExplorerNov 19, 2015Onan 5500 or 6500 generator. Very easy to change brushes mounted that way.Pogoil.dougrainerNomadNov 19, 2015Onan Genset. Mounted sideways due to mounting in the front of the Motorhome. The pass side would be the actual "front" of the Genset. DougbarmcdExplorerNov 19, 2015Okay, Most of the generators I've seen in motor homes are in a metal box so you don't see much of the mechanical parts.wolfe10ExplorerNov 19, 2015Air filter is black box on the left with the two on-generator breakers below it.gboppExplorerNov 19, 2015wolfe10 wrote:Electrical end of generator.Yep, and it appears to have an hour meter at the top right.wolfe10ExplorerNov 19, 2015Electrical end of generator.
Related ContentIs this something to be concerned about?Is this safe?Zion Healthshare SD, anyone have any experience with this company?this is whyChew on this.
