- TechWriterExplorerThanks all! I think I've also noticed this box under some RV island beds.
- IAMICHABODExplorer IIIIt is the fuse box,
Here's below the seat, shows the back of the fuse box and the storage tube for the table leg.
- PartyOf_FiveExplorerAgree with above. Ours has two latches you can turn with a coin in the top left and right corners and then the top half of the panel holds down on a hinge to reveal the fuses etc
- eHoeflerExplorer IIPower center, has your 110-volt breakers, 12-volt fuses, and convertor
- rlw999ExplorerThat's the fuse box (and I think the Power Converter is in there too) -- press in on the top of the cover and it should release the latch. The latch on the one in the Cruise America unit I rented was broken and it was duct taped closed.
38,778 PostsLatest Activity: Jun 06, 2026
