- Bird_FreakExplorer III built mine 18X40. It was perfect with slides out.
- chuckftboyExplorerMy coach is 8'6" wide and I have opposing slides that are 30" deep so like Rich said, at least 15' to give you a little room on the outside but if you have the option for more, you'll be much happier.
- rk911Explorerif you make your carport 15-16' wide you should have enough room to be able to walk around the RV. wider, taller and higher for the next RV is not a bad thing.
- azdryheatExplorerClass A's generally have 4 slides. If you figure 3 feet per slide you're looking at around 14 feet total width. Some are less, some more.
- IvylogExplorer III12’6”
38,774 PostsLatest Activity: Apr 26, 2026
