j-d
May 15, 2016Explorer II
SweetWaterSurprise wrote:Is this particular MH a 4x4 unit? If so, there may be height to work that 30-ton that some of us don't have...
I keep a 30 ton jack in my HM. Lifts the rig slowly and easily.
OP,
That Harbor Fright will lift it easily. 20-ton. Remember, the whole RV is say 14,000 or 7-ton.
Problems are:
1. Sometimes a really powerful jack (like 20) works out to be too tall to get under the axle when the tire's flat and ground is uneven.
2. There aren't very many contact points on the rear axle till you get close to the differential. That means you're lifting say 2/3 of the rear axle weight to get one pair of wheels off the ground. That's only say 6,000 or 3-ton, but
3. It gets very awkward to pump a bottle jack from a prone position under a vehicle. So, a 5-ton WILL lift it, IF you have an extension handle with room to swing it, OR you're really strong.
I have 2- 4- 5- 10- and 12-ton bottle jacks. So many because I was given most of them. Bought the 10-ton (Harbor Fright) when we got the E450, because I thought my good, big, old, and heavy 12-ton Walker had given up the ghost.
The 4-ton will lift one corner of the FRONT. The 5-ton will lift one corner of the rear but the leverage is very difficult. The 12-ton lifts the rear easily. I like the 10-ton because I've found I can get it, and a jack stand, out toward the wheel end on the rear axle and raise the coach without slithering all the way under.
Of course if you have a compressor, an air-over jack makes life really easy.
So for me, on a Class C, for that matter most any GAS coach, if I had one jack it'd be a 12-ton. I went to HF to get a 12. They were out of stock and 10 was on sale. They don't offer that size anymore, and I think an 8 wouldn't be enough to comfortably lift the rear.
The Low Profile 12- and 20-ton are intriguing. Question is do you want to pick up from low, or to be able to lift a little higher (low profile vs. standard)? I have seen double-extending bottle jacks, where they were really squatty but got good height because they had a telescoping ram, a piston within a piston. These low profile HF jacks are NOT that type.
38,767 PostsLatest Activity: Jun 10, 2019
