Guyver280z's avatar
Guyver280z
What RV to buy for my towing needs?
Hi everybody. I've been looking for a Motorhome capable of towing a two car trailer, but when I search RVs nobody mentions its towing capacity and most of the time the owners only know the motor's HP but not the Torque rating and I know that's what I need to figure out if its going to be good or not for my needs.
I'm looking to spend less than $35,000 on the motorhome and I've found some big diesel pushers for around that price or less, but some research has led me to believe that the engines on those are not going to be enough for my towing needs, so here's what I need and I hope you guys can tell me from experience what would be a good RV to buy.
-I don't need a lot of room so actually a short RV that sleeps 4 people is good enough.
-Is a Diesel pusher better for towing that a front engined diesel?? and is a V10 gasoline engine an option?? (I rather do diesel tho)
-I want to tow a two car trailer with two lightweight racecars (maybe 2,200lbs each, so maybe no more than 8,000lbs.
-Also I don't need it to be super fast, but just reliable on uphills (no warming up or running out of power)
Thanks a lot for your help!!
Moved to Class A Motorhome forum from Towing at OP request.
  • Kingsley Coach
    Probably more than you want to spend but one of these Class 8 conversions would pull anything you want. Seen some homemade projects over the years where people have mounted used campers on the trucks rails themselves. Might give you your best bang for your buck. Lots of towing capacity.
