Bill_Satellite
Apr 12, 2017Explorer II
Everything is correct except that you will not be able to use an existing Cable connection to run your satellite TV receiver. There is at least 1 splitter in there that will prevent this. Depending upon the setup, however, it's likely a very easy modification to add an A/B switch and change around a bit of coax wiring to make it compatible. You may also simply be able to run a new dedicated cable in a window or through the coach firewall (even drill through the sidewall and install a coax plate) for the easiest installation.
38,766 PostsLatest Activity: Jan 10, 2026
